Discuss amount adhesive needed per sq mt to fix limestone/porcelain on floor in the Canada Tile Advice area at TilersForums.com.
jonnyc
have just done a porcelain floor this week . The tile company who supplied tiles and who i have an account with supplied 14 bags x 20kg tilemaster setaflex for 60.00 sq mts of tiling.
i normally supply the adhesive but this was a lead from them and they were already supplying materials.
if it was my job i would have quoted supply of 30 bags based on a level subfloor. In reality of course the screed is rarely level and to allow 2.00 sq mts per mt is what i expect to use on average, bearing in mind i am not just notching floor but solid bed tiles and levelling floor out.
I know why the tile shops only supply so little adhesive because they dont want the whole package from them to seem too expensive but the question i am asking is how much do you alllow for per sq mt.
i have been quoting against other tiling firms that allow less than half what i state and have lost jobs because i am being realsitic.
peteablard
1,058
Cheshire
Re: amount adhesive needed per sq mt to fix limestone/porcelain on flo
The floor was ok but as the tiles got thinner I had to build up. Was using Dunlop large format and natural stone addy (which I wasn't a big fan of) but can be bedded up quite thick. Tiles ran though 3 rooms and trying to slc in sections as the tiles got thinner was far too impractical IMO
Peter
Usually use a 12mm square notch & backskim method on floors. On a reasonably decent floor I would allow 4m2 onto screed/board but allow 2.5-3m2 to Ditra. Last job of 15mm marble on Ditra was giving me on average 8x 600x600 tiles with a drilbble left in the bucket - probably works out just under 3m2.
jonnyc
this has been very interesting and revealing.
I can see that i am way out compared with the majority who are between 4.00 and 4.50 sq mts per sq mt.
this does explain why i have lost a number of jobs this year where costs are being scrutinized and pared away to get the best deal.
in fact most of you guys have confirmed that my tile shop supplied almost exactly what the average has been quoted here on this thread.
the only reason i can explain how i get to my figures i guess is that i am self taught , and when i was trying to impress the high end kitchen companies when i started out and maybe also not understanding that you can get away with a floor not being totally level , i was obsessed with all my floors being perfect.
maybe when you are inexperienced as i was and learning as i went along , i could not think out of the box or entertain the bubble being not exactly in middle of the markers .
jonnyc
so i laid every floor dead level within the parameters of the quality of level used .
if a subfloor was more than 10mm out of level ,i laid loads of floors(limestone ) in a mix of sand/cement/ flex adhesive mix with a light skim of adhesive on back of tile and sub floor .i never gave a guranatee of this method.
if i used plastering sand I could easily bed stone solid bed to 7mm
as time has gone and i accept as you move up the market then the quality is better and more level.
in recent years i now find myself in a position where i am typically doing a ground floor area in domestic residence of hundreds of sq mts. no worries we can adjust heights between rooms but a common factor is that the surround where the datum is marked is level but you tend to have a drop in middle in large open plan.
here lies my problem. i am still obssesed with giving a perfect dead level floor .
i think that most of the 4.00 sq ,mts per bag boys will just go with the floor and drift over the worst spots. but it wont be level!!
does this matter ?
i know it does not but it is very hard to get out of my mind set and that which i have instilled in my employees.
i have a refina box section 2.50 lin mt straight edge and everything we do revolves about this great tool. for 20 years it has been my benchmark by which to judge how good our tiling is and i dont expect to see a gap more than 1mm within this distance .
Reply to amount adhesive needed per sq mt to fix limestone/porcelain on floor in the Canada Tile Advice area at TilersForums.com
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
