Discuss Amtico laid onto existing ceramic tiles in the UK Tiling Forum area at TilersForums.com.
SandyFloor
Actually you can under certain circumstances.
Your tiles will need to have the polished surface removed thoroughly to allow adhesion. They will then need to be primed with non diluted F.Ball Stopgap P131 primer. The screed will need to be Stopgap 700 flexible which give an extremely smooth finish. Over tiles this may need two applications.
Your main problem is removing the polished surface which can be done by scrabbling or abrading for which a machine is usually required. Probably best to lift the tiles...I usually do.
Aston
totally agree with sandy about laying amtico if the existing floor is sound, mechanically keyed, primed and then slc'd BUT
your post asks can you lay amtico onto a 'very smooth, polished surface, so i am assuming you were asking if you could lay directly onto the tiled floor, as there was no mention of a self levelling compound...if thats the case, then i still say no.
but if correctly prepared as sandy explained then obviously it will be fine ;0)
ed
Reply to Amtico laid onto existing ceramic tiles in the UK Tiling Forum area at TilersForums.com
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
