Discuss Anhydrite screed in the UK Tiling Forum area at TilersForums.com.
Another interesting point is: Walls are rendered with sand/cement yet plastered with Gypsum.
I have never come across the plaster separating from the render??
Am i worrying about something that happens to a small % of jobs most likely having not prepared the site in the 1st instance.
What do the Europeans use, they use more anhydrite than the UK and in general more tiles too.
I wrote that
Ah that clears up a point for me Alan, I have just received my copy of Tiling to calcium sulfate screeds, published by the tile association. And I noticed there was no mention of decoupling membranes, unless I missed something. And yet a few years ago I was involved in laying a large tiled floor on a calcium sulfate screed at a college where the college "boffin" checked the residual moisture levels with his hair hygrometer, we primed the floor with an epoxy primer, then used Ditra mat prior to tiling,
This was specified by Ardex, was this overkill? I understand the need for decoupling on sand and cement screeds, due to shrinkage etc, but just wondered is it not needed on calcium sulfate screeds?
Thanks in advance, Phil.
All screeds have the potential to crack, as unfortunately found out by a previous customer of mine that decided against my recommendation to use decoupling membrane on her Anhydrite screed floor. Luckily the crack in her tiles only covered a few pieces and i still had just enough stock of the same batch to get a match
As I understand the characterisics of Calcium Sulfate screeds, are and I quote from the TTA paper "minimal shrinkage, negligible cracking and curling", so I asked the question, are decoupling membranes necessary? with Calcium Sulfate screeds?
PS I have been a great advocate of decoupling membranes on any suspect substrate, but I am now wondering if I am giving the wrong advice to customers.
What do you stick the membrane to the Anhydrite screed?
And can 600 x 300 tiles be laid on them?
But there is on the inside of the front cover a full page advert for gypfix ?
Reply to Anhydrite screed in the UK Tiling Forum area at TilersForums.com
