Discuss AnhyFix in the Canada Tile Advice area at TilersForums.com.
Stef
Will the tiles just be sat over that big whole when you come to actually tile stef? If not how will you be filling it? Sorry if I'm taking it off topic. Cheers
That will be filled in with granite & then I will stick a tile down into place.
It doesn't really need fixed as its just to cover up where the pipes will go, it will never see any foot traffic.
Stef
Can’t say I’m that impressed with that bond. You pulled itof the dabs with your hand and scraped the adhesive of the floor with hardlyany effort
Deano, I already had a go at that tile, 3 or 4 attempts to pull it up, that took a lot of effort to get up & those dabs didn't want to move.
If you have a solid bed under those tiles then it isn't going to move.
Stef
You were able to remove the dabs with a scraper and a smallamount of effort no hammer required. Do the same test with Weber SPF on to aS&C screed and see if you can get it up with the same action as you did inthe video
I've removed tiles easier than that from screeds.
I know what you mean but that adhesive had only been down about 12hrs.
The point I was trying to put across is that there are a few people scared from these screeds & they don't need to be if using appropriate adhesives & primer.
Spud
I got my son to take a faulty tile out of a floor we tiled with anhyfix he took over 3 hours to remove it and no piece was bigger than a 50 pence piece the customer commented on it when I went back to Silicon the expansion joints it was solid bedded and backed the adhesive is unbelievable and i am really really impressed with it ,I didn't watch your video just telling of my experience with it
Reply to AnhyFix in the Canada Tile Advice area at TilersForums.com
Hi everyone, I'm tiling a 150 meter square meters onto a anhydrite screed. Laitance has been...
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
AnhyFix
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
