Discuss any tips for removing addy from a floor?? in the British & UK Tiling Forum area at TilersForums.com.
Q
quackfly
hows it going all. just a bit of brain picking from you lot. a friend has asked me to tile his kitchen floor with a 13 inch tile, no other info on the tiles yet, now the existing tiles are to come up and although i havent lifted them yet i would like to be prepared for doing it. how best should i tackle removing the addy assuming the floor is a fairly typical screed one. i know its a dumb question givien i dont know exactly what im dealing with but any general help will defo give me some peace of mind and insight to what i might expect. thanks lads and lasses:hurray:
Q
quackfly
like i said the tiles arent up yet, i'm only gathering info on what methods i can use depending on what i find. i know the house isnt yery old and its a groundfloor kitchen so im assuming it might be screed. time will tell. also would coarse sandpaper on a handheld belt sander be any good at the end of any chipping i might have to do?
K
kngjason
If you really want to save time and a huge amount of effort.
Hook up a tile or two. Check it is indeed a screed floor. If so (assuming all tiles are fixed and secure) latex over the whole lot; tiles an all.
NOTE ***
Check yer heights thou before. i.e existing height + latex + tile thickness. Would you still be able to slide dishwasher, washing machine etc under the work top for example. Using the latex gives you one of the best sufaces for accurate speed tiling there is.
NOTE**
you may still need to shave some of bottom of plyths and doors to accomadate new floor height. I dont do that as i always say "im a tiler not a carpenter" lol
Reply to any tips for removing addy from a floor?? in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
