Discuss Any tips on fitting Porcelain wall mosaic? in the British & UK Tiling Forum area at TilersForums.com.
Stone
My kitchen fitter has swerved fitting my kitchen wall tiles. They are a brick mosaic porcelain tile in sheets 300 x 300.
I have bought (what I think is) a recommended powder based adhesive and just wondered if anyone could advise on preperation ie Unibond yes/no........thickness of adhesive on wall 2mm/4mm?.... butter sheet of tiles yes/no?
Is there a problem with them falling off the wall? I have an electric diamond tile cutter and have done a reasonable amount of DIY tiling before with decent results but my 'mate' has made me doubt myself on this and the tiles were very expensive so don't want to be chucking them or washing them off!!!
Any tips gratefully recieved.
Mick
GazTech
You can just use a normal wall trowel for those tiles mate.
BAL mosaic fix is about the best on the market (in my opinion) for fixing mosaics, more expensive but well worth it :wink_smile:
Spot on as usual Var,mosaic fix is one of the best adhesives known to man
reaper72
Cheers for the reply. The tiles are 8mm thick. The only adhesive I could see for porcelain was Wickes own brand 'For stone and percelain wall and floor tiles"
Is the main problem that they don't absort water like ceramic?
Totally right,they don't absorb moisture like ceramic almost all porcelain are what's known as full bodied or fully vitrified -if they're a light colour,use a white rapid set....
Reply to Any tips on fitting Porcelain wall mosaic? in the British & UK Tiling Forum area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
