Discuss Anyone installed geberit wall mounted wetroom drain in the Canada Tile Advice area at TilersForums.com.
Looks great stuff, but its a fortune tho.
Found this video for installing the waste , comes with a unbelievably complicated mixer support .
http://m.youtube.com/watch?v=F9kVnwrUWZI&desktop_uri=/watch?v=F9kVnwrUWZI
Gebrit Is the best in my opinion and you will get spares in 30 years. The glass one is expensive as its designed to stand alone, the glass can slide up to get access.Use Geberit all the time and love it. Good quality and easy to change parts down the line)
Any of your 4 toilets one of these? View attachment 55529
you could just use one of their wall frames and the get a piece of glass cut and drilled to a template.mirror adhesive this to a piece of ply and bolt the wc back. you get a foam gasket with the geberit, but i have bolted one back to a mirror before and i ran a bead of clear silicone around the wc edge the day before as a cushion. this would be a lot less than the above.
Customer loves the toilet in the brochure but turned to the wet room drain an also loved that.
Reply to Anyone installed geberit wall mounted wetroom drain in the Canada Tile Advice area at TilersForums.com
