Discuss Applying sealer to large travertine floor in the British & UK Tiling Forum area at TilersForums.com.
_Adrian
Hello again!
I've laid my travertine (tumbled and unfilled) floor and have thoroughly cleaned it, and allowed it to dry. After some reading on here and a call to LTP, I've decided to seal (LTP Mattstone) prior to grouting (as recommended by them. I know opinions differ on this, but I'm just going to do it!). My question is about application of the sealer over a large area. The room is about 6m x 5m, and LTP suggest applying the sealer then after an hour wiping off any excess... but if I do this I'll have to walk on the floor. Is this what you guys do - and it doesn't mark / leave footprints in the sealer?
My plan B was to work in a strip that I can reach, then wipe off excess almost as I'm going. This won't give the sealer the hour LTP recommend (well, I suppose it could if I did a strip per hour, but would rather not wait!) but does that hour need to be strictly adhered to?
Just wondering what you guys normally do.
Thanks,
Adrian
_Adrian
Sealed the floor this morning - went really well. Paintpad works much better than a foam roller which I'd used once before. Applied the sealer all in one go, then walked around the block (house in the middle of a terrace!) and through the front door to where I'd started :) Then put on some overshoes (great idea, thanks) and even taped a couple of plastic bags over my knees, then set to on the buffing... Karate Kid moment... wax on, wax off...
Thanks for all the advice.
If it is unfilled i would grout before applying sealer.
Oh well, too late. I did ask LTP and they recommended sealing first. I hope it'll be OK...
Mike
Some seal first, some after, it depends how well you want the pits/holes filled. They will fill more if grouted unsealed.
tapatalk on my HTC
Reply to Applying sealer to large travertine floor in the British & UK Tiling Forum area at TilersForums.com
gamer1
Hi all. After living in my property for over 7 years I've recently discovered the type of tile...
Hi ppl Need advice regarding sealing kitchen tiles. I believe I have lappato tile laid on my...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
