Discuss aqua board, tanking??? in the British & UK Tiling Forum area at TilersForums.com.
Danny@ Diamond
Hi mate aqua board is a waterproof backing board that replaces the need for plasterboards and ply boards.
The backer boards can be used on walls and floors and it comes in various thicknesses.
The idea is you fit the backer boards then apply a coat of waterproofing paste , you then tape all of the joints with tape then when its dried you apply a second coat of paste.
The room is then water tight and ready for tiling.
Hope this helps mate:thumbsup: :thumbsup:
grumpygrouter
I have to disagree slightly here. Aquapanel or other proprietory cement based backer boards are designed to be water resistant, as such they need no further treatment to protect them form water/moisture. It is normal to seal joints between boards with either the manufacturesr recomended filler or tiling adhesive. I have never heard of putting a further coat of "Waterproofing Paste" on them afterwards
Maybe Essex Tiling could enlighten me as to what they use for this "paste". Please don't say PVA!
DHTiling
Droopy
I agree with GG.
No need to put 'waterproof paste' ( I think he means to tank) onto aquapanel or the like.
Unless you are Mike Holmes, from Holmes on Homes that is. :grin:
sWe
My opinion is that if the board comes pre-covered with waterproofing compound, you only need to tape and proof the joints, and the screw holes.
If it doesn't, I'd tape and proof the joints and the screw holes, as well as doing two coats of WPC on the entire surface.
Alternatively, I'd cover the whole surface with a waterproof membrane, an example of which is Schluter Kerdi, which I've read some of the inhabitants of these forums use.
It varies though, as I chose system depending on the requirements of the of the job at hand, and what the circumstances are.
In the end, it comes down to what the manufacturer supplied instructions dictate. If they say "go forth and waterproof everything, and his niece", then that's what I do.
Saw a real cool system being used some time ago, which was sprayed onto the substrate. Thick, and perfect fit, kind of like my ex girlfriend :grin:
Anyways. Waterproofing is not an art. It's a science. The guys who design waterproofing systems tend to have a good grasp of it. Read their instructions and guidelines. Don't just storm ahead into the unknown without really knowing what you're supposed to do, as it'll return and bite you up the arse one day.
:thumbsup:
Cheers.
grumpygrouter
Funny that G G as i run courses in tanking and have professionals in to teach this side of things and they all agree that although the backer boards are waterproof tanking them is advisable to make absolutely sure that it is 110 % waterproof.
Bit of a funny comment about the PVA as well mate.
I have to confess Essex Tiling that I have only been in the trade a short time. This, however, is the very first time I have heard that a "waterproof" substance needs a water proof coating to improve it's waterproof-ness! Some thing is by definition, either waterproof or it isn't. Applying an extra layer over the top is not going to make it any more waterproof than it already is. Unless of course you are referring to the joints and seams which, if the manufacturers of the products instructions are followed, should be appropriately sealed and taped.
As for the comment about PVA, i was wondering if your "Waterproof Paste" was actually PVA based. Sadly you seem to have bypassed my question.
Danny@ Diamond
Hi G G sorry mate the system i use is Dukkaboard with Mira 4400 multicoat and Mira safecoat / seal manchets.
The other system is by Granfix .
Dont really like getting into heated debates over things , just giving the best advice based on what i know.
Also in the other post re grout joins i was giving advice based on what jobs we had actually done and not by bs standards which was wrong of me so sorry mate .:thumbsup: :thumbsup:
N
Northern Bird
I think it makes it harder beacuse of the amount of products on the market.
The most important is finding out from the company not the tile staff as sometimes they get it wrong and this can lead to all sorts of products.
In my research there a many types of products I am sure you can all name half a dozen that fit these categories:
1. Waterproof products
These products do not allow any form of water to penertrate the membrane/ barrier that is created. They do not break down, even when in continous contact of water. Example: Bal WP1
2. Water reisitant products
These absorb a small portion of water and release over a period of time. These types of products do not break down in contact with contact with water. Example Hardiebacker
3. Non suitable products
This is more items like untreated ply, chipboard, plasterboard which can rot, swell or disintergrate when in contact with water.
I am sure this will raise a whole heap of problems and choice words but I hope this helps
grumpygrouter
Thanks for clarifying that. I am not familier with the products you mention except for Granfix adhesives. Maybe that is where the misunderstanding has arisen.:thumbsup:
Reply to aqua board, tanking??? in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
Hello all. I'm doing a total refit of my bathroom, including the floor which is water damaged...
I'm looking for some expert advice and hopefully some reassurance.... I've just had a complete...
5K
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hi I orignially posted this Eeeek Advice appreciated please -...
    Votes: 9 5.3%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.7%
    Votes: 21 12.3%
    Votes: 40 23.4%
    Votes: 4 2.3%
    Votes: 4 2.3%
    Votes: 24 14.0%
    Votes: 19 11.1%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
