Discuss Aquadefense over Joint Compound? in the America Tile Forum / Advice Board area at TilersForums.com.
Hi folks. I hired a guy to hang and prep backerboard around my tub surround, so that I can start tiling it. However, when I came home I discovered that he’d used drywall mud/joint compound not only to connect the drywall to the backboard, but used it to feather down several inches to flatten out from the joints all around. Additionally, he filled in the 3/8” thick gap between the bottom of the backboard and the tub edge, also using drywall mud. When I told him I thought that was only done with mortar/thinset, he said that since we’re covering everything with waterproofing membrane, it will be fine and no water will ever reach it.
Hm.... I’m not so sure about this….
What do you guys think? Does waterproofing membrane make everything honky-dory, even drywall mud in a wet area, forever? Or should I plan on chiseling this stuff off and replacing it with mortar?
Thanks for any help you can give!
Reply to Aquadefense over Joint Compound? in the America Tile Forum / Advice Board area at TilersForums.com
  • Sticky
23K
Deleted member 57709
Hi ya guys! I live in a flat, and as such I have to run most structural things by a maintenance...
7K
steadsy-boy
USA Tile Forum Popular
America Tile Advice Trending
Seattle
What member type are you?
  1. Homeowner
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
