Aqualisa Quartz Electric Shower Fault - Identify Part Discussion ThreadAqualisa Quartz Electric Shower Fault - Identify Part Electrical Advice
Hi All
I have an issue with my shower and I suspect it's the solenoid.
The original fault is that the shower either wouldn't switch on at all, or it very briefly powers on, see video
I removed the front panel and as you can see below, manually pressing the plastic arm starts the water flowing, and it is heated too (i know the danger of using the shower in that state whilst live) so there is no issue with power reaching the unit.
I suspect that the faulty part is the solenoid, but is the part (arrowed below) actually the solenoid, as it doesn't look like other I've seen?
And if so where can i purchase a replacement? P/N FW343A1P1
Many thanks
Aqualisa Quartz Electric Shower Fault - Identify Part for the original thread on Electricians Forums
Hi All
Many thanks
