Discuss Aquapanel for shower/bath area in the British & UK Tiling Forum area at TilersForums.com.
N
newplumb
Hi there. Would appreciate some advice on approaches to tiling on to Wickes Aquapanel, which I'm using to replace two existing plasterboard walls around the customer's bath (with overbath shower). Tiles are likely to be 20x25 or 25x40 format.
Would be grateful for opinions on the following:
  • Best way to secure panels to studwork (ceramic head screws?)
  • Is it necessary to use primer?
  • Which adhesive/grout would you recommend.
  • Any other useful advice!
Many thanks
Matt
grumpygrouter
Aquapanel mproduce their own screws I believe. If not try drywall screws, you may need a cup washer to spread the load but I am not sure.
There is no need to prime aqua panel but I suggest you read the adhesive manufacturers instructions.
For adhesive and grout, it all depends what is available to you and how quickly you need to to be ready for grouting. A flexible rapid setting adhesive will give you a quicker turnaround but if you are inexperienced at tiling a standard set adhesive may be more suitable. Are the tiles ceramic or porcelain as this can also have a bearing on adhesive choice. For grout, a flexible grout such as BAL microflex will be fine but my personal choice would be Ardex or Mapei.
Reply to Aquapanel for shower/bath area in the British & UK Tiling Forum area at TilersForums.com
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
