E
easyt
I am using just two sheets of Aquapanel on the end wall of a shower As a studd wall on 25mm thick battens. The two sheets are one above the other. Remaining wall are sand and cement render.
I will tank the rendered walls. Rather than use aquaseal jointing tape for a 900 mm horizontal joint I intended, originally, to silicone that joint. Could I use a strip of the tanking joint tape and tank over that strip. Any point in generally tanking the Aquapanel?
