Discuss Armeg tile removal chisel? in the British & UK Tiling Forum area at TilersForums.com.
H
hillhead
Hello all,
just back from Florida this week(great holiday),
as usual the work has piled up me,pressure,pressure,pressure.!
Anyway i'm in need of a SDS PLUS rotary stop drill with one of them good tile removal chisels,3 jobs coming up with removal included!
I would appreciate comments on what to buy?? i'm not buying the cheapest unless its great,don't mind spending around £100 -150 for good quality.
Thanks all.
And by the way i was inspecting mickey mouses kitchen wall tiling in disneyland,cool,hehe,
robbo
Bought this one recently m8, tis a bit heavy but lifted a tiled floor easy..
Erbauer 6kg SDS Drill
Robust design delivers outstanding performance when drilling, hammering or chiselling.
  • 1300W
  • Single-Speed Variable & Reverse
  • All-Metal Gearbox
  • Lock-On Switch
  • Soft-Grip Handle
  • Replaceable Brushes
ERB015SDS, auxiliary handle, depth gauge, drill bits, flat chisel, pointed chisel, dust cover, plastic container grease, 2 x extra carbon brushes.
was £79.99 £63.99
Mark B
Hi Hillhead,
I have used the Armeg chisel with my 4kg Makita to lift floor tiles and they came up a treat, running it over any residual addy and it lifted all that cleanly as well.
I haven't tried it yet for wall tiles as I'm not sure how much (or little) damage it will do. I waiting for a job where it's going to be replastered / boarded to try.
Mark
Gazzer
I recently bought one like this but mine had a lot more bits in the case and core drills too. Titan SF25X2.2 6kg SDS Plus Drill - Screwfix.com, Where the Trade Buys
Its very good , heavy though but eats its way through anything i have tried so far. Oh and i got the Armeg bit too.
H
hillhead
Hi Hillhead,
Mark
Hi Mark,
i have a few great makita tools in my van and will check them out for sure but am open minded on what to go for,the first job alone will cover the cost of one quite a few times over so i'm happy.
Mark B
Hi Mark,
Hi Joe
My Makita gets some real stick - from addy mixing to core drilling and 600mm masonry bits !
They're not cheap but you know they won't let you down. I bought mine from Anglia Tool Centre - they were the best price I could find at the time.
Mark
CLAYS TILES
with this chisel...
Armeg SDS Plus Tile Removing Chisel
Best for removing tiles without damaging walls & flooring
80mm blade, cranked to allow easy removal of tiles without damaging flooring or wall behind. Can also be used to remove plaster. For SDS Plus machines with roto stop.
£29.99
this chisel is selling on ebay for less than £8 with postage!
i bought a Bosch PBH 2200 RE SDS rotary hammer drill & chiselling machine with case and accessories i paid £99 but found it just on amazon for less than £60...............
Amazon.co.uk: Bosch PBH 2200 RE SDS rotary hammer drill & chiselling machine with case and accessories: DIY & Tools
philg43
The chisels that are on Ebay are not Armeg chisels, they are similar which is stated in some of the adverts.
Anorak on now, please bear with me !
I am unsure of the quality of these chisels as I have not tested them.
If an SDS chisel fails it usually fails across the shank where the SDS grooves are machined.
Up until a few years ago you had to have a license from Bosch(who invented the SDS drive system) to produce SDS shanked accessories. This involved being visited by Bosch and having your products tested by them to make sure they satisfied their specification regarding materials, heat treatment, tolerances etc. If they didn't like what they saw you didn't get the license.
That license has now expired and so anyone can make SDS accessories which is now happening with varying degrees of quality.
The 2 major problems are:-
1) incorrect heat treatment - this means the chisel can snap across the SDS shank which usually means you have a piece of shank inside your power tool chuck which can only be removed by a power tool repairer (it may mean a new chuck).
2) incorrectly machined grooves on the shank. There are two different types of groove on the shank. There are two drive grooves(the squarer ones) and two "ball nosed grooves". The ball nosed grooves accept spring loaded balls to stop the accessory from falling out of the chuck. If the drive grooves are machined too wide, the accessory turns slightly in the chuck and it tries to drive on the spring loaded balls. This can cause damage to the chuck and can also make accessory removal difficult.
I am not suggesting that the Ebay products are poor quality, as I said I have not tested them, they may be very good.
I just wanted to make people aware of the problems associated with cheaper SDS accessories.
Also, when you use SDS shanked accessories, grease the shank at regular intervals, try to minimise leverage and allow the accessory to cool at room temperature if the shank becomes hot. These measures should prolong the life of your accessory and, more importantly, your power tool.
Reply to Armeg tile removal chisel? in the British & UK Tiling Forum area at TilersForums.com
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
Any advice on removing difficult tiles welcome. I've got about one third of the old tiles off...
6K
WetSaw
Hi all Hoping for some opinions on how to handle an ongoing issue in having with my tiler He...
2 3 4
15K
Hi guys, I need to do some tiling with 500mm tiles and I'm looking for a decent yet...
13K
White Room
Hi, I have removed the floor tiles from my kitchen floor but need to get the adhesive type...
9K
White Room
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
