Discuss asphalt floor needs screeding in the UK Tiling Forum area at TilersForums.com.
2020Tiling
hi, got a 8mtr asphalt kitchen floor to tile on sat/sunday, but the floor has a couple of high spots and a couple of hollow sounding areas , my plan was to take the high spots out and fill the voids with a rapid set cement, and break away the hollow areas and also fill with a rapid set cement , then prime with sbr then screed. is a latex screed ok for this type of substrate ? the customer laid the floor himself around 40 years ago i think he said ! this is my first asphalt floor.:yikes:
2020Tiling
thanks dave , i think i might take the hollow bits out and the high spots tomorow and see if it opens a can of worms or not !( il take some pitures ). to be fair the guy mentioned it was a asphalt floor otherwise i wouldnt of known ? it just lookes like concrete ?? quite scary :speechless:.... is there a way of knowing the difference or does it just come down to experience ?
Reply to asphalt floor needs screeding in the UK Tiling Forum area at TilersForums.com
I'm about to tile an area 2m X 10m in a kitchen area. The floor is covered with floor grade...
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
David John
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
