Discuss At what temperature do you feel underfloor heating? in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Human body temp it 37.5. Your hands will generally hover around 25 degrees although could be anywhere from about 15 to 32. Therefore you will not feel the floor as warm untill it is warmer than your hands (assuming it is your hands you are feeling it with).
The usual surface temperatrue for the underfloor heating in a lounge would be set around 20 to 24 degrees. This will generally give a comfortable feeling. The floor should not feel hot but at best tepid. You should not run it too hot for extended periods of time and bear in mind that underfloor heating run too hot has been linked (tentatively I'll admit) to problems of DVT particularly in the elderly.
wilfredolimb
Hi guys thanks for such fast response, the floor is made up of no more ply, mapei fibreplan slc and mapei flexible addy with latex
the tiles feel cold not room temp
the controller is the elecktra OCC2 1991, and I have it set at manual 15degrees, it doesn't have a Reading of what the thermostat is, atleast I can't find it :mad2:
should I just wack the temp up to 25degrees it something?
Ajax123
1,213
Lincolnshire
NO NO NO NO NO! :yikes: - keep building it up slowly :thumbsup: else you could thermally shock the tiles and that could crack em.:thumbsdown:
MarkyD
Here's a link to the manuals and programming guides. LINK The display does have a temp reading. Pressing both the UP and DOWN buttons together for 3 secs takes you to the INFO screens
When I commisioned my screed I did a week of 1 deg rises to 25deg (was at 19deg when started) left it at that for a couple of days then let it cool for a week or two. When finished my controller (Magnum) has a new floor program which gradually increases the temp to working temp over 20 days
Mark
wilfredolimb
Mark
thanks Mark I'll try this when I get home and report back :smilewinkgrin:
Reply to At what temperature do you feel underfloor heating? in the UK Tiling Forum area at TilersForums.com
Hi guys, Hope you are all having a fantastic Xmas. To cut a long story short I have installed...
gamer1
My tiled bathroom floor is new but I have moisture seemingly seeping up through the grouting in...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
