At what voltage should a 1.5V battery be replaced? Discussion ThreadAt what voltage should a 1.5V battery be replaced? Electrical Advice
Hello,
I used two 1.5v batteries for the remote AC. (AAA/R03P/1.5V) and Its expiration time is 03.2025.
The battery is weak, and the air conditioner cannot be turned on. I replaced it with two new batteries and the problem was solved.
I measured the voltage of both batteries. They are 1.54 volts. Why did they weaken and not work on remote AC? The voltage is 1.5 volts and they look good.
At what voltage should a 1.5V battery be replaced? for the original thread on Electricians Forums
Hello,
