• Thread starter MikeJhn
  • Start date
  • Replies 0
  • Views 202
Discuss Atkinson tank top oil feed Discussion Thread in the Plumbing Advice area at TilersForums.com.
As title anyone using one, good? bad? ugly? has to feed through a de-aireator to the boiler, but should not be a problem, my question is, should the oil line be insulated up the side of the tank, if so how do you attach the insulation to a plastic tank? Pipe being used is green PVC covered, would this be sufficient?
https://www.tanksrus.co.uk/assets/media/2024/04/26/atkinson-top-off-take-valve-datasheet.pdf
Atkinson tank top oil feed for the original thread on Plumbers Forums
Reply to Atkinson tank top oil feed Discussion Thread in the Plumbing Advice area at TilersForums.com
TF Group Please Join
Plumbing Advice
Tags
None
