Discuss B&Q Polished Porcelain tiles in the British & UK Tiling Forum area at TilersForums.com.
DaveW
I'm about to have 20sqm of black B&Q polished porcelain tiles (600 x 600) put down. After everything I'd read about these I was bit sceptical but my wife insisted (and I couldn't argue with the price).
It seems that with all the reported problems with these tiles B&Q are trying to cover themselves and are now recommending the tile should be cleaned (to remove the wax coating; using heavy duty tile cleaner) and sealed before fixing. This differs from the instructions on the box which suggests that you should fix, then seal before grouting (but doesn't mention removing the coating; which seems to be the cause of a lot of peoples problems) and then seal again after grouting.
The idea of going through 15 boxes of these and cleaning and sealing them before laying doesn't appeal. Is this really necessary or just B&Q covering their arses? If I lay them with the coating still on and then clean and seal before grouting am I likely to run into any problems?
I'd appreciate any advice from anyone with experience of these tiles.
beanz
Berkshire
You shouldn't really need to seal before fixing, just work as clean as you can. If they're anything like the 400x400's, make sure you check the colour. The ones we fitted in my mates house were quite clearly brown, not black (he couldn't be bothered to take them back!?!).
Personally, i'd save for a little longer and get some decent tiles. Nothing worse than looking at them forever more and thinking "I wish i'd taken them back, that's not what i wanted".
Good luck with whatever you decide to do though. :thumbsup:
seal before grouting as a friend of mine had a problem of the grout impregnating the tile on the edges therefore soaking into the tile.He ended up taking it all up as it looked a right mess and swore he would never use b+q s**t again(his exact words) He also said some of the tiles were slightly different sizes so beware
Perfect Tiling
Dave...I recently laid 24 sq mtrs of these tiles in a piano showroom. So long as you work clean and seal prior to grouting they seem fine. I left the sealer on for a day to really soak in and got no staining at all. He used an electric buffer to get a good shine so you can see the underside of the pianos. Beware of tiles that aren't flat though...we had about five that for some reason were high in the middle, so kept them aside for cuts around the edges. Not bad tiles for the price they ask...good luck.:8:
Reply to B&Q Polished Porcelain tiles in the British & UK Tiling Forum area at TilersForums.com
Hello Tilers! I am a homeowner in California and I thought I'd come say hi in search of a...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
