SteUK
Hi all,
Going to be fixing 'no more ply' backer board to a mixture of wall substrates (both breezeblock, one with old sand and cement render, the others the same but with a plaster finish skim). Will be solid bedding (8mm square notched trowel) with mapei keraflex maxi, and mechanically fixing with 55mm x 5mm stainless steel screws into Fischer 50mm universal plugs (internal breezeblock is only 50mm thick!).
Question is...should I be using stainless steel washers as well? The screw heads are approx 3mm deep and 10mm in diameter so not much wiggle room depth-wise on 6mm thick boards!
Thanks!
Thanks!
