Discuss backerboard layout and adhesive in the Australia Tiling Forum area at TilersForums.com.
E
edgren
Hi, first post here.
Having read many posts on the use of ply vs backerboard, I have decided to tile over existing sound floorboards in the hall using 6mm Hardiebackerboard. The board is 1200 x 800 and the width of the hall is 1260mm. Would you recommend a 60mm strip along a wall edge where no one walks or should I be making them even sized, even though the join would be in the centre of the hall with the most wear.
Also, I notice on the Hardiebackerboard site that in addition ot the mechanical fixing the adhesive fixing should be non flexible whereas everyone seems to recommend flexible. Does it matter? Is there an adhesive you recommend as I'm overwhelmed by all the different types. Thanks
Stef
Hi, spin your board the other way & you will have a 460MM cut instead of a 60mm cut.
Stagger all joins though.
Hardi state a non flexi addy but I almost always use a flexi addy, it just sits better in my head with it being a wooden substrate.
I have used non flexi without issue so it's whatever you want to use.
I use weber adhesive & use a slow set SPF (single part flexi) for fixing Hardi or Weber set +.
Any adhesive from Bal, Mapei, Tile Master etc will suffice.
Fix your Hardi using 25mm screws, I use turbo golds from ScrewFix, you will see where to fix them within the grid pattern on the boards.
I mix my adhesive slightly wetter than I would fixing tiles.
E
edgren
Thanks for the replies. Houston, if I lay it across the run of the boards that will still leave me with the 60mm edging question? Stef, my builders merchant have offered Aquapanel instead of Hardi. That comes 1200 x 900 so I'd have 360 cut instead. Is Aquapanel a worthy substitute for Hardi? It's cheaper but a £50 saving isn't my priority. Thanks
Stef
I've never used aquapanel & don't know much about it so I couldn't comment on it,
Looking at this again I wouldn't worry too much about a 60mm rip, the Hardi is going to be glued & screwed anyway, it's trying to get a 60mm cut that's the problem.
You will have to use a saw or grinder to cut a strip this thin but it is do able.
Make sure & use a mask if cutting Hardi as it releases some bad chemicals...
Stef
Reply to backerboard layout and adhesive in the Australia Tiling Forum area at TilersForums.com
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
I am planning to tile bathroom with large porcelain tiles 1200x600 over water-resistant backer...
Hi all, I'm struggling to get a tiler in my area since lockdown so I have taken the bold...
Good evening to all. I’m here this evening looking for some advice if you would be so kind...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
