deffo bagged gear......Bal ctf3 is champs for ceramics of that format..flexi if they were porcelain.....ctf3 sets in 16hrs so plenty of time to work with it...has about a 5 hr pot life.....
BAL CTF 3
White, cement-based, polymer modified, non-slip, water-resistant and frost-resistant adhesive suitable for fixing ceramic wall and floor tiles, ceramic mosaics, quarry tiles, natural stone, terrazzo and brick slips. Suitable for a variety of backgrounds/bases including concrete/brick/block walling, cement:sand rendering, gypsum plaster, plasterboard, fibre cement sheets, cement:sand screeds, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet, mastic asphalt.
Conforms to BS EN 12004, Type C, Class 1T. NOTE: The physical properties of BAL CTF3 can be enhanced by the addition of BAL ADMIX AD1, with a classification of BS EN 12004, Type C, Class 2T.
Coverage:Based on 3mm thickness:
Thin Bed Solid Bed Trowel = 3kg/m2
Thick Bed Solid Bed Trowel = 4kg/m2Bed Thickness : 2-6mmOpen Time: 20 mins Setting Time: 16 hoursPackaging:Available in 20kg, 10kg bags Shelf Life: 12 months when stored in normal, dry conditions. Protect from damp.Temperature Resistance: -30°C to 150°CPot Life: 5 Hours
