I have to do a wet room next week. Its being tanked out and then a Heated floor is being laid. The tiles are ceramic 300x300 in the main floor and 50mm mosaic in the shower area. The sub floor is boarded and no problems with flex at all.
So whats the best BAL adhesive to use.
Please note only BAL as thats my choice.
Either this or the rapid flex is great for this type of installation...if tiles are marble then go with white not grey.....Gaz:yes:
BAL Single Part Flexible
A flexible, non-slip, water-resistant and frost-resistant wall and floor
tile adhesive, especially suitable for fixing tiles, including fully vitirfied and porcelain tiles to low porosity backgrounds/bases. Suitable for use on concrete/brick/block walling,
cement:sand rendering, plaster, plasterboard,
cement sheets,
tile backer boards, concrete bases,
cement:sand screeds, plywood overlay, ceramic/quarry
tile/terrazzo/hard natural stone, vinyl tiles/sheet bases, mastic asphalt. Conforms to BS EN 12004, Type C, Class 2T.
Coverage: Based on 3mm thickness:
Thin Bed Solid Bed Trowel = 2.5kg/m2
Thick Bed Solid Bed Trowel = 3.75kg/m2 Bed Thickness : 2-6mm Open Time: 20 mins Setting Time: 16 hours Packaging: Grey 20kg, White 20kg 10kg bags Shelf Life: Grey 6 months when Stored in normal dry conditions. Protect from damp.
White 12 months when Stored in normal dry conditions. Protect from damp. Temperature Resistance: -30°C to 100°C Pot Life: 5 Hours
The Bal 10 Year Guarantee
Click here to download
Material Safety Data Sheet
Product Data Sheet
