Discuss BAL Tank Kit in the UK Tiling Forum area at TilersForums.com.
ah666
Hi Quick bit of advice, just purchased a BAL Waterproofing Kit for a shower (WP1) in a tub, didn’t have any instructions so I have looked up on BAL website, The instructions seem a little confusing or I may be misunderstanding the terminology :
The walls this is to be applied are for a shower and are new Moistureshield Plasterboard, with 2 internal corners
I have been supplied with Waterproofing which is in a tub and some reinforcement for the internal corners
And from the instructions this is my understanding of what I need to do :
  1. Tape all edges (do I add the corner reinforcement at this point ?)
  2. Apply skim coat of BAL adhesive
  3. Prime with APD
  4. Brush on WP1 in corners and taped edges (or do I add corner reinforcement here ?)
  5. Apply 2[SUP]nd[/SUP] coat of WP1 to corners and tape (how long do I leave to dry ?)
  6. Apply 2mm thick coat to complete area
  7. Leave to dry for 24 hours before tiling
Have I understood currently and when do I apply the corner reinforcement ?
AH666
DHTiling
Info from Bal..
APPLICATION/USAGE
Do NOT use in temperatures below 5°C or in damp conditions.
Usage procedure
1. Prime all surfaces with BAL PRIME APD and allow to dry
(15-30 mins).
2. Using a suitable brush or steel float, apply
BAL WATERPROOF COATING at:
– Internal and external corners of walls/partitions
– Wall junctions with bases/upstands/columns
– At pipe penetration points/drainage channels/outlets
– Junctions of different bases/background materials
– Cracks and joints in background/base
3. Reinforce with BAL POLYESTER TAPE.
4. Apply second coat of BAL WATERPROOF COATING over
the BAL POLYESTER TAPE.
5. Using brush or steel float, apply BAL WATERPROOF
COATING to primed walls at a max. 2mm thickness.
6. Apply BAL WATERPROOF COATING to primed floor.
7. Reinforce with BAL POLYESTER MATTING (may be cut
to correct size with scissors).
If applying in heavy duty wet areas (e.g. communal showers
and industrial wet process areas) and/or where some vibration
or deflection in the base may be expected (e.g. timber bases):
8. Bed matting into coating and apply a second layer of
BAL WATERPROOF COATING over top.
9. Allow membrane to dry for min. 24 hours before tiling.
Reply to BAL Tank Kit in the UK Tiling Forum area at TilersForums.com
Hi, I am a keen DIYer and have chosen an Impey Aqua Dec 4 and waterguard tanking kit. The Aqua...
Good Morning, with the bal waterproofing kit, you do the following: prime with apd apply...
BAL Tank Kit
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
