N
newreno
I'm about to start a DIY tiling project next week with 600x600mm porcelain tiles. 10mm thick. Doing walls and floor.
I haven't worked with anything this size before so I have a basic adhesive question. I'm looking to use a 10-12mm notched trowel for the walls. Once the tiles are pressed down into this, how much adhesive will still be visible if you look straight on? I.e. how much will the 10-12mm compress?
I'm considering stopping halfway along a wall to save some time and using trim to block off the tiling. The rest of the wall will just be painted. The problem is that the 'stop' will be quite visible when you walk into the bathroom. 12mm trim seems like the solution, but will the adhesive really compress down to only 2mm (10mm of trim for the tile thickness, 2mm spare for the adhesive)? Or will I end up with a space behind the trim? I could fill this with grey Silicon I suppose (the same colour as the grout).
Sorry that this is such a basic question. I've had a search but can't see anything immediately similar...
Cheers lads.
Cheers lads.
