Discuss Bath panel and floor in the UK Tiling Forum area at TilersForums.com.
Skid Solo
Hi new to the forum and have found some very useful information, however I have a couple of questions relating to a tiling project :
  • I want to have tiled bath panel (20x25x6 ceramic tiles), the bath is 1700mm long. I originally thought of using exterior ply to make the bath panel and tiling directly onto this, but having read through this forum, this doesn’t appear to be the best solution. So I am considering using Hardeibecker board and tiling onto this (I have used this before to tile bathroom floor and will be in this project as well). However I cant get 1700mm long Hardeibecker board so how do I join ? Thoughts are to make bath panel from 9mm exterior ply and screw 6mm Hardeibecker to this and to tile onto the Hardeibecker. Does that sound suitable or am I making this to hard ?
Would this also apply to a boxed in toilet system, I was thinking of making frame and using plasterboard on the front wall with a exterior plywood and Hardeibecker board to make up the top surface, so that it could take some loading if ever required
  • Secondly and I am sure this must have been asked before, but I couldn’t find a direct answer, should I tile the floor before or after installing sink pedestal and toilet pan ? I have tiled a bathroom floor in the past where the units were already installed so had to cut round them, not the easiest thing to do. This time however I have completely gutted the bathroom and I am installing new sink, toilet and bath so was hoping to tile the floor 1st and then install sink and toilet, your recommendations would be appreciated
Skid Solo
Thanks David, however not sure I understand, I want the bath panel to be removable, and thus I will need a joint of some type as the Hardeibecker is not long enough to make a complete panel.
Are you therefore suggesting that the joint should be on a batten and that one side of the joint should be a permanent fix to the batten and the other side of the joint held on with chrome topped screws (so they can be removed at a later date), how would I ensure the joint gap between the tiles was the same as all the others, would it be grouted and then have to be re-grouted when and if the bath panel was removed ?
diamondtiling
Install your stud framework and make sure that it is solid with no deflection whatsoever.
Fix the hardie to the frame , where the hardie ends you should have a double or thicker batten for strength. Cut the smaller piece leaving a 2mm gap between the panels and leave out for the time being, tile the longer panel. offer up the smaller piece and tack with pins into place, take the measurement and alignments for the tiles that will be on this smaller panel and tile it either in situ or lay it on the floor. When this panel is tiled drill your holes through the tiles for your capped screws, offer it into place and fix. Grout the whole panel but leave out the 2mm gap where the panels meet, when all the grout is dry Silicon the joint to match the grout. You should now have everything in place and the inspection panel should have 4 capped screws. one in each corner, I would have some in the middle as well. If you need to open the panel, just cut through the Silicon and remove the screws.
It is imperative that the stud work is solid or the panel may pull in too tight leaving you with a lip at the join.
:thumbsup:
or another option is making bath panel from 40 mm wediboard, fixing it with expanding foam, start laying tiles and cutting out access panel for like 1-2 tiles depends on valves where need access, then putting back access panel and Silicon tile joint, Silicon will hold access panel in place, and you will not gonna see any screws, if you need to remove access panel then need to cut out Silicon, some people never look under bath, that's why i prefer this way it looks more tidy i guess :)
Reply to Bath panel and floor in the UK Tiling Forum area at TilersForums.com
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
