Bathroom advice, Aquaboard Adhesive?
jubba
Hi guys,
I am a bit of a novice but did a good job on my kitchen floor and wall tiling with some great advice from this forum. :thumbsup:
Just doing my bathroom now so figured this was the place to come.
Just erected a new stud wall and got some aqua-panels from wickes today, which I am going to fit around the shower bath area.
What i need advice on is a good adhesive to use?
This will be used to seal the joints and fix the jointing tape on the aquaboard.
Going to fit ceramic tiles 250 x 400.
I would prefer to use ready mixed adhesive as it will make the job alot easier for me.
Screwfix do : Bal Bluestar?, unibond?, mapegrip d2?, all suitable for showers?
Also the wickes guide recommends fitting the tape to the aquaboards "immediately before tiling" but surley i could do this in advance as long as I just put a thin coat of adhesive on?
You advice appreciated :smilewinkgrin:
Lee
Thanks again Scottley,
Just read the stickey post on "PVA Vs Primer" very informative and now appreciate that he should not and will not be applying PVA to seal the surface! :thumbsup:
In that thread they talk about sealing render and gypsum coats with primer prior to tiling? Is this not the same as bonding coat?
Can an alternative to bonding coat be used as long as primer is applied to avoid the cost of having it skimmed?
