Stoobydale
Hi, I have a lot of questions that probably cross a few forums so hope it's ok to ask them all here.
I have removed the tiles from my bathroom and as a result have had to renew 3 walls as behind the tiles it was lath and plaster and it all came away. I have purchased 10mm Marmox board and am in the middle of putting this up now. I have screwed CLS timbers to the original frame work to get a pretty good/flat frame for the marmox. I have also purchased Hardi backer boards for the floor which will go over floorboards that are in good condition. I have chosen the tiles that I want, Zamora glazed porcelain 600x200 for the walls and 300x300 for the floor. Now for the questions. (think the tiles are 9mm thick)
1, Adhesive, I have read the forum until my head hurts, could someone please tell me what to buy for the floor and wall (the tiles are coming from Topps tiles, could buy from there if they sell good stuff, although if it is cheaper to buy elsewhere not a problem)
2, What size trowels should I buy?
3, I have a tile cutter that I bought a long time ago from Machine mart. I think I tried to cut porcelain tiles with it once before and it was not man enough. Is there anything on the market for £50-60 that will do the job or should I hire one?
4, Hole cutting, similar to above, I saw a kit advertised on the forum for a bathroom set £50ish was thinking of buying and possibly selling after. Good idea or not?
5, The bathroom was only half tiled before and I plan to fully tile. The top half of the wall has being painted (brick plaster substrate) what is the best way to prepare? Could I just score the surface?
Thanks in advance for any answers. Don't think I have remembered all the questions but that should keep me going.
