Discuss bathroom plasterboard. in the Bathroom Tiling Advice area at TilersForums.com.
boldydave
hello all.just wanted some advice.i`ve ripped all the tiles off in my mums bathroom and 1 wall(the exterior wall) is now bare brick as all the plaster came off.the other 3 walls were plasterboard which all came off with the tiles.my plan is aquapanel screwed to the studs around the shower area and plasterboard dot and dabbed onto the brick wall and to do the window recess.how do i prep the bare brick and can i use normal 12mm plasterboard?also are aquapanel fixings needed or can i just use normal drywall screws recessed.does aquapanel need to be tanked.thanks in advance. dave.
Reply to bathroom plasterboard. in the Bathroom Tiling Advice area at TilersForums.com
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hi all, I'm redoing my bathroom that I did 15 odd years ago. Before it was tiled with 20x20...
Tilers Forums on FB
