J4CK THE RIPPER
Started a complete bathroom refit and just wanted to ask a few questions.
1. Brought Topps new tanking kit (homelux waterproof matting) for around showerbath area 5 m2 the topps rep recomended using rapidset flexible to fit matting would it be ok to use BAL Grip ready mixed to tile over matting?
2. When removing old tiles large areas of plaster had blown on one part of wall i knocked all the lose stuff and was going to plaster with one coat plaster is this ok to tile onto?
3. On the floor i have removed floor boards and was going to reinforce the joists with noggiins and use tonge and groove chipboard 18mm then coat the back and edges of 12mm plywith BAL bond SBR and screw over the top at 300 centers. Would BAL rapidset flexi and microflex wide joint grout be ok to use?
I have done some research on what materials would be best to use but would like some experienced advice (and tips).
Thank You in advance.
