E
Edinaberdeen
Hi, I am planning to renovate my bathroom and I am after any tips or guidance.
I know its going to be a big job but I am looking forward to giving most things a try though I will get someone to do some parts. The plan is to strip the lathe and plaster back to the stud/rafters and change sink, toilet and bath with shower screen.
Its going to have travertine tile on the floor and ceramic on all of the walls. I would also like electric underfloor heating.
I have the sink, toilet, bath with screen, taps and tiles. I am going to reuse current shower attachment which is mains pressure from a combi boiler.
The roof above the bath follows the rafters on a 45 degree slope, its about 2x1m.
I am planning hardiebacker 500 on the wall with the sloping roof and the ajoining wall around the bath which also has the toilet. Also thinking about homelux membrane over the hardiebacker in the shower area. Gyproc MR on the other walls and ceiling.
The floorboards seem solid so far (still mostly covered with laminate)but aren't perfectly flat.
I see my options being sand the boards down a bit, lay thin ply or take the boards up and lay 22mm ply.
Then 10mm Marmox insulation board and underfloor heating before tiling with 457mm sq 12mm travertine.
After speaking to Marmox they suggested I could use it around the bath instead of hardiebacker.
Is this a good idea with for hanging 36x27 9mm ceramic tiles on a 45 degree slope?
The tiles are about 16kg /m2 which is well below the 60 kg /m2 limit
Thanks Ed
Thanks Ed
