ah666
I am about to start a bathroom refurbishment in my house, and have a few questions about the best way to do things, any advice would be great :
The grout within the current shower has come out so I know its going to be a mess behind, all tiles are coming off and I am expecting to replace plasterboard. For best results do I :
I would then tile up to the bottom edge of this ledge with wall tiles (on Hardiebaker as used previously in my 1[SUP]st[/SUP] bathroom refurb as recommend on this site)
If I can’t use Granite then my thoughts are to basically create a tiled box that the bath sits in, however in this instance I would be very concerned about the corner of the bath which sits in the middle of the bathroom, if I have a square box the it would be a very sharp corner therefore
ah666
- Replace old plasterboard with new Plasterboard and then tank
- Replace old plasterboard with Aquapanel and no tank
- Replace with 18mm ply ply, install heating elements and tile straight onto this and if so should it be exterior quality ?
- Replace with 18mm or 22mm chipboard and then 6 or 12mm Hardiebacker , install heating elements and then tile onto this ?
- Anybody got any experience of Karndean flooring as I have been recommended this by a colleague, would this work OK with underfloor heating, yet to see samples, so its only an idea at the moment
- I am concerned about height of floor compared with the bedroom which leads into the bathroom so want to keep the height difference to a minimum
- I don’t want to make it circular as it will not match the bath
- I don’t want to use plastic tile trim as this will make a very sharp corner (and to be honest I think a 3 way mitre in the middle of the room would be beyond my skills)
- Can I get tiles that have a suitable edge so I don’t have to use a trim, I think they used to be call bullnose
- Any other ideas ?
ah666
