Discuss Bathroom shelf in the Bathroom Tiling Advice area at TilersForums.com.
GazTech
mark where you want the holes in the tiles to be for a rawlplug,level and with a pencil .Mark the holes,then take those tiles off the wall to make sure there is no pipework where you want the holes,if no pipes,re-tile and grout,then drill the holes in the tiles with an electric drill.Place rawlplugs in the holes and screw the shelf up using a screwdriver hope this helps
Or you could always leave tiles on and use an electronic pipe/wire detector
Dan
Admin
Staff member
5,088
1,323
Staffordshire, UK
Drill the holes, if it leaks its the plumbers fault, he can get over that...oh got that around the wrong way its the plumber who says the tiler can get over that!!!!
Nice one lol
I recently tiled the walls of a new shower room. I was wondering, how can I install a shelf on a tiled wall without removing any tiles? It will be used to hold shampoos and soaps.
How would you do it even by removing tiles?
I'd go in the room the other side of the wall where you want to hang the shelf and then take a few bricks out the wall or cut through the plasterboard and then scrape out the grout from the back of the tiled wall and push through some kind of home-made car ariel / coat hanger affair and just hang the shampoo bottles on that. Then build the wall back up and decorate it, bobs your uncle. Tell the mrs you dropped the shelf and get an extra lottery ticket just incase she boots you out.
I just thought it had a few serious answers and needed a controversial opinion too.
Reply to Bathroom shelf in the Bathroom Tiling Advice area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Bathroom shelf
Unsolved
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
