teacake
I'm tiling 2 walls in my bathroom and would like suggestions on best products to use.
Tiles are ceramic 200 x 300 x 7mm thick being put onto new plasterboard with 2mm spacers. The two walls are not around the bath so will get minimal splashing. I'm competent but not a professional. I'm wondering about the following:
- Does the plasterboard need any priming before tiling
- Bead size to use for adhesive - is 6mm ok or should I go bigger
- Adhesive - tubbed (Bal Whitestar / Mapei D1?) or bagged cement based - if bagged have you any recommendations. Because I'm not as fast as a pro I would benefit from one with a longer open time
- Are any grouts more suitable than others for a non pro.
