Discuss Bathroom Tiling in the Bathroom Tiling Advice area at TilersForums.com.
I
ipocock
Hi, hope you can give me some advice but we have been told by a tiler that our bathroom does not have waterproof plasterboard and we need to replace our plasterboard with it. I am concerned about this on the basis that we have walls and floor tiled and I would have thought this was sufficient.
Could you advise if we should have waterproof plasterboard installed.
Thanks you
Scott
If its in poor condition then its not worth messing about with as the materials are cheap enough to replace. However there are differetn routes you can choose, you can choose for standard board and tank as already mentioned, or you could replace with a cement backer board like Aquapanel or Harddibacker, there are lots available.
Aspect Tiling
As above, I always recommend waterproofing the substrate with a membrane/tanking kit. However there are plenty of people who don't do this and will continue to do so. Without it there is a risk of water ingression through grout lines/poor sealing damaging the substrate leading to the tiles falling off.
I wouldn't say it's necessary for you to rip out and start again, unless there are signs of water getting through to the plasterboard which will only get worse. Just bear in mind the advice given about tanking for future projects.:thumbsup:
L
limco
Using plasterboard in bathrooms over here in Sweden is now forbidden, because of the paper on the plasterboard- so it's now water proof boards we use, and we also use the membrane/tanking kit..........
We have 2 Zones now- Zone1: is where the shower or bath is- and zone 2: is 1 meter out of Zone 1.
Membrane: should be used on the floor (the whole bathroom )
No Bathroom in Sweden will be insured, unless the bathroom has been done by a
registered tiling company, and they must follow the Swedish tiling rules.
Insurance companies were flooded with claims for damaged bathrooms, and the main cause was plasterboard in the bathrooms!
You have to really protect Zone 1: as this is were most of the water is, so try and use water proof board there & the membrane
Reply to Bathroom Tiling in the Bathroom Tiling Advice area at TilersForums.com
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
Bathroom Tiling
Unsolved
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
