Discuss bathroom in the Bathroom Tiling Advice area at TilersForums.com.
Deleted member 1779
Agree with Hillhead !
If your shower tray has a raised lip you have to tile OVER the lip so water runs into the tray
You have to fit this item first (dont remove the plastic protective cover though - usually blue)
However any appliance that can be retrofit after the tiling should be done so.
The shower tray HAS to be fitted first because of that lip.
The tiles are run over the lip so the water flows into the tray.
Store everything else safely (another room etc!) while you tile the room
So you can tile the room FIRST then fit your white goods second they will look amazing.
Items like the above toilet, sinks and radiators can be reto-fit provided that you bring through the service pipes.
As Hillhead said if its a FIXED BATH then it needs to go in first.
If you are bringing through service pipes you can either rough cut the tiles where they wont be seen.
Or we supply a tile drill kit to give you accurate and perfect holes where you need them.
Where you need accurate hole to fit things like sinks or radiators we supply a fixing kit.
This tile drill kit has EVERYTHING you need for service pipes as well as rawl plugs.
Install shower heads, Body Jets, Radiator pipes. Shelves, Brackets etc.
E
easyt
Whilst I agree in principle with all that has been said and I am not an expert - I have always tiled the walls and stopped (leaving a cut row Normally) above the shower or bath. Then fitted the shower or bath and completed/ Only because I dont want to butter finger a tile up near the ceiling and have it fall into the bath and i also want easy access to tile.
Deleted member 1779
I think the consensus is that ANYTHING you can remove from the working space will help
so good point !
Tile it FIRST and fit second - anywhere you can. In this example again the shower tray HAS to be fitted first.
The toilet has gone in second. And now the shower door is going in.
One slight drawback to moving big items in small spaces (that includes baths and glass shower doors) is that they can be bulky to swing about so be careful of those fresh laid tiles.
The bath above was not so much "heavy" but an awkward bugger to move due to its size.
The background provides a tempting array of objects to swing into. The bathroom was no exception either !!!
Bathfix Bob
588
I've started doing this now easyt, you only drop one tile on a bath, I've done it and there's no way thats happening again!
Scott
Bath boards guys its the way forward, especially if like most of the tilers here you dont fit the bathrooms first. I have a piece of ply that fits most baths and shower trays along with a thick canvas dust sheet folded double underneath as a chushion to stop any scratching. It alo stop you standing in the bath/shower tray, something which has always irritated me about some tradesmen
Reply to bathroom in the Bathroom Tiling Advice area at TilersForums.com
Small bathroom tiling job in Stockton on tees ASAP, 90cm by 230cm approx. I have tiles, adhesive...
bathroom
Unsolved
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
