If i find floor tiling too much of a challenge following standard procedures, would it be OK if I took my time and literally back trowelled the tile only and laid 1 tile at a time like that?
I had a go at trowelling the floor with a 10x10mm square notch to lay 20x20cm tile but made a bit of mess and ended up scrapping the idea and cleaned the floor and tiles ready to go again tomorrow.
I have a feeling my mix was a bit too wet , I followed the instructions 25Kg bag should use 5 litres of water, so I mixed 5Kg to 1 litre. And tiled onto ditra matting. I'm guessing because its plastic that the water doesnt go anywhere very fast. Do I need a slightly dryer mix? The comb lines looked wet and streaky.
I might try to back trowel the tile rather than to risk trying to trowel the floor again.
What are the potential drawbacks to doing this?
Cheers.
Cheers.
