Discuss Beginner wet room assistance please! in the UK Tiling Forum area at TilersForums.com.
Deanspoors
Hi there, this is my first post. I don't like to start on a new forum with questions, but hopefully I can provide some answers in the near future or at least experiences after my tiling episodes.
So my query, I have a bathroom, currently 18mm chipboard floor. plasterboard walls. (unplastered). I need to make this into at least half wetroom. So far I have a 20mm wetroom shower tray and;
  • 1 litre BASF PCI Primer​
  • 4 kg BASF PCI Lastogum​
  • 5 metres flexible tape for securing all joints/connections​
  • 2 flexible internal corners​
  • 2 flexible pipe collars
bought from ebay.
I have done a lot of research and there appears to be a number of ways to waterproof and decouple, but I would like someone to come along and tell me what exactly to use.
I would prefer for the flooring to be as thin as possible. It seems like I should use 6mm tile backer board screwed down then apply Dural CI for waterproofing and decoupling.
With the walls, would it be adequate to seal between the un-plastered plasterboard with flexible tape and then lastogum to seal?
Thanks in advance for everyones opinions and experience.
Dean
BARRONBATHROOMS
Floor needs to be defection free.
Chipboard IMHO will not be!
Theoretically it is pointless over boarding with cement board as this adds no strength to substrate. Dural or sheet membrane (as I like to call it) is my preferred method to waterproofing a room! Wet rooms need a lot of thought and work to be successfull
PHG
Hi Deanspoors, depending on the tray used , they can span joist width with no extra support between joists , but it is wise to support between the joists as in line out with ply to support tray deflection.
Membrane tanking is a prefered method by some as it also acts as an anti crack membrane on timber based sub-floors as well.
If you wish to discuss your install and prices and supplying you with what is required then you can ring day time on 01388-776211 , look forward to helping you get your wetroom project sorted.
Reply to Beginner wet room assistance please! in the UK Tiling Forum area at TilersForums.com
Hi All, First time poster and tiler here. Hoping to get a bit of advice on tiling a wet room...
Hi All over from the electrical forum, was hoping you may be able to give me some advice. i am...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
