Discuss Best cable type for in floor heating Electrical Advice in the Electrical Advice area at TilersForums.com.
Best cable type for in floor heating Discussion ThreadBest cable type for in floor heating Electrical Advice
I am planning on redoing my basement floors and debating on adding underfloor radiant heat. It would be supplemental to my HVAC as the basement as being 70 year old house all registers are roof mount.
My question is due to the large area of main room roughly 13' × 30' (4m × 10m) 400 square feet or 40 square meters. This leads to my current problem, most single cables are less than 100m (300') or harder to find, (I've only found a single 1000' cable which is what I'd need to do the entire room). What seems to be an easier solution would be to run 10 parallel runs of heating cable. Using 33ohm/m cable that would roughly be 10 × 110Watt circuits. Which of these would be the better option. The single cables systems seem to all run around 3000-4000 Watts.
Is there any disadvantage to running the parallel circuits rather than the single cable system?
Best cable type for in floor heating for the original thread on Electricians Forums
Reply to Best cable type for in floor heating Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
