Guest viewing is limited
Tiling Tool Suppliers
Discuss Best cutter for a Rotozip in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Jason
I bought a Rotozip thinking it would be handy to be able to cut out shapes for sockets and switches out of tiles but the ceramic cutting bits I bought are naff.
It takes an age to cut through the tile and then to cut a length I'm there all day. The cutter just heats up and starts glowing red and dosn't really cut at all and then of course the metal of the bit is comprimised once it's started to glow and melt.
Has anyone come across a good bit for a rotozip that will trully blunge cut and then cut out a section of tile in a reasonable length of time. I'm at that point where I don't even care how much it costs.
Deleted member 1779
May I suggest something.....
DHTiling
Yep that's right.
It just seems that the cutter bits overheat very quickly and cut so slowly through the tile that unless there are some kind of much better cutter out there then this piece of equipment is of no use to me and yet other tilers seem to make use of them.
The methd you use is , you plunge the bit in the tile and then move the cutter up and down as you gently push forward so that you are getting an even wear on the bit and not putting the stress on one part of the bit.
Watch this video and it shows you how to move the bit keeping it cooler
[yt]NG7hxzFS45I[/yt]
Reply to Best cutter for a Rotozip in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Welcome to the Which Tile Cutter is Best? Thread I'm tidying up the forum a little bit, and in...
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
my trusty old wickes wet tile cutter never got returned last time i lent it out. but only cost...
5K
I'm taking on my first tiling job in my utility room. Planning to just tile around the worktop...
Popular Tile Cutter Threads
    Votes: 5 5.8%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 22 25.6%
    Votes: 13 15.1%
    Votes: 26 30.2%
    Votes: 3 3.5%
    Votes: 2 2.3%
    Votes: 18 20.9%
    Votes: 14 16.3%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 3 3.5%
