arpee
Hi, can anyone help me select the correct adhesive for an external tiling job?
I am tiling an external terrace with a wooden substructure. Above the wooden sub-structure I plan to fit a waterproof moveable membrane (Ditra) , and tile over that.
It will be important for there to be minimum risk of water ingress through both the grout and the adhesive, and because of the wooden structure there needs to be maximum flex in both the adhesive and the grout.
The surface will also have an external drain fitted and we need to try to ensure minimum seepage of rainwater between the edge of the drain installation and the adjoining tile edges - I'll probably silicon around this area and tile up to it.
Tiles will be porcelain, 600x600, around 10mm thick, total area around 12 sq. meters.
Any suggestions?
Thanks in advance for your help.
Any suggestions?
