Discuss Best primers, adhesive, grout combination? in the British & UK Tiling Forum area at TilersForums.com.
chrisab
Hi,
I've got a mix of plaster board and skimmed walls, I was going to use BAL Prime APD, tiles are just thin ceramic ones. Which ady and grout should I use?
Any poitners to other primer/ady/grout combinations much appreciated? Are the anti-stain grouts worth it? Should the grout for the shower area be a particular type?
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
You want to tank the shower area. Prime all plaster with a primer. Tile with a cement-based or suitable dispersion (bucket) adhesive. And then grout with a cement-based grout.
What brand you use is your call. But I would make sure I used all the same brand products to make sure all guarantee's are solid and can't be questioned should anything ever fail due to products used.
Reply to Best primers, adhesive, grout combination? in the British & UK Tiling Forum area at TilersForums.com
Hello everyone, I'm about to lay some antique 6"x6"x 0.5" ceramic tiles, all clean and dry, onto...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
