Discuss best self levelling laser in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Moved to tools forum.
Try these from tradetiler......
Stabila LAX 50 Self Leveling Laser
The Stabila LAX 50 projects crossed horizontal and vertical lines in a matter of seconds both perfectly levelled.
Complete with combined tripod/telescopic pole kit and carry pod
Unscrew the tripod legs and screw together to form the telescopic pole. Simply clip the LAX 50 on. The telescopic pole can be fixed between floor/ceiling heights of up to 2.75 m.
If placed directly on the ground, its working height is as little as 7 cm.
Can be rotated through 360° on the tripod
Range of visible laser line easily 10 M in normal lighting conditions
Horizontal accuracy: +-0.5mm/m
Requires 3 'AA' Batteries (included)
Nice and bright with a good narrow beam from a trusted brand!
Laserliner Autocross 3 (lastest version)
WE HIGHLY RECOMEND YOU USE THIS WITH THE LASER SLIDE BELOW
How many of you already own on of the cheap lasers but never use it because it is not accurate and too difficult to set up?
German fully-automatic, self-levelling cross laser
Magnetically damped pendulum system with locking device for safe transportation.
Laser cross and vertical laser line at 90° to laser cross.
Using the two vertical beams perfect 90° lines can be generated for setting out floors, like the laser square below. The lines automatically project perfect vertical lines up the walls and cross on the ceiling at the same time.
Gives a nice tight beam even at 20 metres, so there is no guess work
This laser is ideally suited for tiling
Laser slide (NOT INCLUDED see below) provides the ideal support for the laser allowing instant repositioning at any height with in seconds. With this system no re-levelling is needed you can now work to the laser beam with out making datums and staffs. Don't worry if some one knocks into it when it's set up. It just re-levels its slef
Range at least 20m
Accuracy ±2mm/10m
Laser diode 3 x 635nm Class 2 <1mW
Self-levelling range ±4.5° pitch and ±4.5° roll
Visual out-of-level indication (flashes)
Power 3 x 1.5v AA batteries included
Duration 15 hours approx
Includes:
Padded zip carrying case included
Rotation base for smooth turning (threaded to go onto tripod)
Crosshairs sub base to allow standing over a pinpoint squaring origin under the laser
Slope made can force the beams not to self level for use on angles
Laser receiver ready NOT INCLUDED (can detect
laser lines at a range of up to 50 m - ideal for outdoor
applications.)
You can pick up cheap lasers just about any where these days. We have selected this German Laserliner Auto Cross 3 because it is a top quality tool at an affordable price.
Tradetiler Tiling Setting Out and Tile Marking
Reply to best self levelling laser in the British & UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
