Smudger
Hi Folks, hope we're all well. Having a problem finishing a slate job as my now beautifully level floor (with ufh, board etc) has created a sloping step into hallway ( hall floor is well off level). Was originally intending to use cover strip but it looks naff. My problem is that as the edges were covered, there is a difference of about 1-2 mm between the edges. As these are now going to be visible I want them flush. The edges are exposed so I can get at them with a grinder, but will a dry gring disc trash the edge. I do not want to lift/replace as it could damage ufh wiring underneath.
Other option was to "ramp" hall floor but customer now wants a step as I have done with external tiles. I intend to use steel edging strip to ensure no sharp edge, but I really want a clean/straight edge.
A tip or two from you (my more skilled and experienced advisors) would be much appreciated (I might even go to the bar!!)
Thanks for reading
Martin
Thanks for reading
Martin
