Discuss Best way to apply adhesive , floor job in the Tile Adhesive and Grout Advice area at TilersForums.com.
L
LM
So I've been doing it wrong!
To allow the air to escape therefore allowing the notches to compress for a more solid bed. Swirled like spreading patterns cause the air to be trapped and the compression resistance won't allow the tile to fully colapse the notch and in turn prevents a true solid bed.
Time's Ran Out
Explain where we are all going wrong then John.
Never said you were - just asked why because others might not know!
Me I do it up, down, sideways , swirls, flat backed, ribbed and a bit extra in the corners when required. As long as it's solid bed there should be no air pockets and I wouldn't make the adhesive stiff enough for the ribs not to collapse.
White Room
That's a fair comment John, it's making sure the addy isn't mixed to thick where it allow very little movement and bedding.
Reply to Best way to apply adhesive , floor job in the Tile Adhesive and Grout Advice area at TilersForums.com
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
8K
Tile Adhesive Trending Topics
BAL
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
