- 1
- 513
Doing bathroom with breeze block internal walls, sand and cement render then plaster skim. Unhappy with porc wall tile weight on plaster skim and in any case, lot of blown plaster so decided to remove the lot back to breeze block. Now wondering how best to prep walls, thinking dot'n'dab plasterboard then mechanically fix thru solid points. (Wet areas do same with marmox). Prompted me to think what would be the downside in skimming over with cement based tile adhesive then tiling straight onto that. I'm sure there's a very good reason and this is a stupid question but interested to learn what it is.......
Many thanks for responses.......
