Guest viewing is limited
Discuss Best way to recess porelain tile to accommodate door hinge? in the Canada Tile Advice area at TilersForums.com.
ojtiler
Hi,
Coming to the end of my (long!) project to fit my own wetroom.... I've encountered a tricky problem; I have finished the tiling, but have realised that the hinges I need to fit for the main door are so close to the wall tiles I need to rebate the tile in order for the hinge to fit :yikes:.
Not sure how best to go about this one; for sure it's going to need a machine tool! The only tool I have which may be suitable is a small angle grinder.... I'm thinking I should be able to carefully use it to machine out a rebate? Please could anyone offer some advice - do you think this will work? If not, how best to tackle it? The rebate should be largely obscured by the hinge once it's fitted, but I want to do the job as neat as I can.
Many thanks.
Reply to Best way to recess porelain tile to accommodate door hinge? in the Canada Tile Advice area at TilersForums.com
gamer1
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
