Discuss Best way to tile around a toilet, cant remove it though in the British & UK Tiling Forum area at TilersForums.com.
OK,
In the attached file (very simple drawings lol!) you should get an understanding.
Basically, 1 = shows you the object you're going to mark around. 2 = you fix the tiles around the cut you're going to make and mark (red) distance between the fixed tile and the object, then join those up and cut it off. Leaving you with a corner off the tile. Then offer that up again to the object as in 3 and the (green) distance between the object and the cut tile at each end should also give you the amount you need to cut off the tile to form the right shape.
So you get a pen and with your finger you you touch the object, whilst leaving the point of the pen on the tile right as close to the edge as you can near the cut corner and slide your finger around the object and you'll follow the shape and put it on the tile.
Then use the piano keys technique to cut the tile, or if you can and have a good blade you should be able to push the tile sideways a little on your cutter to cut the shape.
ALWAYS ALWAYS ALWAYS measure twice, cut once, and if you need to, take a little less off as you can always take some more off, but if you take too much off you can't stick it back on... as they say.
Hi any ideas would be welcome, I can remove the toilet to tiles under do how best tile around it, template maybe ?
Tony
Reply to Best way to tile around a toilet, cant remove it though in the British & UK Tiling Forum area at TilersForums.com
