Discuss Big gaps! in the British & UK Tiling Forum area at TilersForums.com.
Gentleman Jim
Hi all
What's the best way round this little problem please.
Bath enclosed on three sides, two ends fit snuggly up to the wall but the long side is stuck out by about 12mm. A trim will span the gap but a) not too many of you like trims and b) the tile would still be pushed back a good way and may look strange.
I can't get to the wall to put a permanent batten up so am a little stuck.
Any ideas?
Thanks.
Jim
Gentleman Jim
Thanks for your suggestions.
The plasterboard idea would work but the wall is sound and in good nick as it is, it would make the job longer and less straight forward. The recessing idea also could work but I've tried "gently" nudging it over but it is kept in place by the waste pipe which I certainly don't want to force.
Looks like it could be time for Mr Trim to pay a visit!
Cheers
Jim
V
vivaro
Dot and Dab plaster board over it...It will only take 15 mins or so to do it...
I hate bathtrims they look crap and attract all the muck under them and then it stinks in time....
dave i agree tile trims do look crap, if there is a very tight gap between wall all around bath, can you get away not using trim , with tile over lapping onto bath and sealing it with silcone , would this work
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
If you cant be bothered plasterboarding...build the tiles out with adhesive....this will take much longer....and be costly...and I totally agree, trims are for DIY'ers only......Gaz
Though to be clear - Gaz means only Bath Trims - Actual Tile Trims do still need to be used by the Pro's too. As bull-noses are hard to find these days.
Reply to Big gaps! in the British & UK Tiling Forum area at TilersForums.com
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi, I have done a bit of tiling before but I will be tiling our shower room soon and we have a...
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
  • Sticky
Hi, Looking to get some advice on a bathroom tile job. I’m doing a herringbone pattern around a...
Big gaps!
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
