Discuss Big ish refurb - a few questions in the British & UK Tiling Forum area at TilersForums.com.
E
EternalOptimist
Moved out of the house while the builders are in - starting to get close to finished now, but there are a few questions you might be able to help me with. The ground floor hasn't changed - it's a solid slab which had 25mm of polystyrene insulation on top, with a 22mm chip floor sitting on top, screwed though to the slab. That had a solid wood block floor on top of it.
All that has been ripped up (except the slab). There are a couple of bits of new floor that have gone down where we've changed the shape of a couple of rooms - there's 60mm of screed that was put down last week to the same height as the existing slab.
Drying time at 1mm/week is a bit of a problem - I want to get a floor down so I can get the kitchen in which will allow us to move back in - usual story!
I've read about the adhesives I can use on green screed - Not sure that wil work for what I want to do - I'm thinking about using a marmox type tilebacker board, (c.40mm) electric underfloor heating, then tiles on top (in the kitchen and utility)
Does that sound sensible? NB the slab is rough - nothing like as smooth as a screeded surface, not sure if the tile backer would sit nice and flat....
All advice greatfully appreciated....
DHTiling
Around 10mm high to low - looks like the original builder got it level with the edge of a board rather than smooth with a float.
OK.....Use a green screed adhesive mixed slightly wetter than normal and float the ridges in to get it flat....then when set use the green screed adhesive again to lay a vapour equalisation membrane...this will allow the floor to dry out and cope with any curling of the screed...
You can then lay your ufh on top of the Ditra and float the mat in with flexible adhesive to hold it down and give a better surface to tile too..
You cannot apply SLC to the new screed the residule moisture will pop it off...as the slc sets to fast to cope with the moisture..
hope this helps..
U
Uheat
Hi ya,
We have got insulation boards similar to Marmox which are cheaper they are called PCS and for a 40mm board you are looking at £16.91 per board. We also do another board called Ekoboard which does not have the reinforced skin to it but is still load bearing up to 30 tons/m2 and has the same U values. These would be £9.20 per board for 40mm.
If you have an idea of room sizes or even a plan send them to my email address [email protected] and i will be happy to work out a costing for you.
Reply to Big ish refurb - a few questions in the British & UK Tiling Forum area at TilersForums.com
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
gamer1
As an introduction, I'm a DIY home owner who has gutted the bathroom in a house built in 1980...
Tony R
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
